Machine Vision
Vision License Detection
Is there a mechanism for detecting a valid vision runtime on the PC?  (https://www.ni.com/en/shop/data-acquisition-and-control/add-ons-for-data-acquisition-and-control/wha...
We have an application that should be able to run in mode A if the vision runtime is installed or mode B if it isn't.
Mode A would require the vision toolkit be installed and properly licensed.
Thanks for your help
(5,107 Views)
I'm not sure you can do that... I think if your application was built with a VI inside of it that requires an active vision runtime licence it wil ask for it when the application is launched.
Maybe if the calls to those functions were in plugins then you could get to your target.
I'm not sure of it all though. Good luck.
Epictetus
Antoine Chalons
(5,103 Views)
Correct.  Deciding if the 'plugins' should be loaded requires determining if the vision toolkit is installed.
(5,100 Views)
I bet the chicken came before the egg Smiley Very Happy
Epictetus
Antoine Chalons
(5,098 Views)
