Machine Vision
Vision Inspection Coordinate System
I would like to be able to create a coordinate system from two points within "Vision Builder for Automated inspection", where the first point (x1,y1) is the origin, and the second point (x2,y2) is the x axis, but also the direction from x1 to x2 is positive.  This does not seem to function in VB4AI, as it will take the coordinates, and use the correct angle, but does not accept direction.
Any help thoughts would be appreciated.
A.
(3,542 Views)
Such a feature is not available in Vision Builder for Automated Inspection (VBAI) - however this might be able to be implemented through the 'Use LabVIEW VI' step which is a new feature in VBAI 2.6. This step allows information to be passed and recieved from a LabVIEW VI - where you could make any calculations or changes to your numbers.
(3,535 Views)
Is there a way to do it without LabView?
(2,656 Views)
