Machine Vision
Vision Development Module
Hey all,
I'm currently in the process of downloading the trial version of the NI-Vision Development Module. Is this a stand alone program? Or do I also require LabView to run this? Thanks for the help.
Cheers,
Kul
(4,144 Views)
Stand alone program
Cheers
Doc-Doc
http://www.machinevision.ch
http://visionindustrielle.ch
Please take time to rate this answer
(4,136 Views)
HI Kul,
The Vision Development Module is a set of tools that allows you access to a number of vision processing algorithms.
In order to use these you need some kind of development platform in order to create programs that use these algorithms. (eg Visual Basic 6, LabVIEW, LabWindows CVI ....)
https://www.ni.com/en/shop/electronic-test-instrumentation/application-software-for-electronic-test-...
It is NOT a stand alone application.
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(4,132 Views)
Sorry Kul, as they keep on changing products name, I am getting confused...
AdamB is right. The standalone application is Vision Assistant or Vision Builder for Automated Inspection (VBAI)
Cheers
Doc-Doc
(4,128 Views)
