04-13-2009 09:52 PM
Recently I uninstalled all NI Software from Add/Remove in control panel due to PC problems. Then I tried to reinstall all NI software. Unfortunately I 've failed to install Vision Development 7.1. Every time I try to reinstalled Vision Development 7.1, system said " higher version of the software already installed not installation required" even that no Vision sodtware install in my pc.
Thank you..
04-14-2009 04:46 AM
Something was not removed from the registry...
Try to use misblast (attached). Use it carefully.
with best regards,
Andrey.
04-14-2009 07:51 PM
I've tried to run Msiblast given by you, an error message appeared: " Error 1316. A network error occured while attempting to read from file: C:\Windows\Installer\vis711.msi". Then when I click OK another error message appeared " Error 1603 occured when trying to uninstall NI IMAQ Vision 7.1.1"
Hart
