Machine Vision
Vision Builder AI 3.5 locking up when trying to adjust Match Pattern
Vision Builder AI 3.5 locks up when I try to adjust the Match Pattern feature in the Inspection step. It appears as if something, maybe the NI Vision Template Editor pops up momentarily and then disappears just prior to Vision Builder locking up. The other features under the inspection step seem to work properly. Any ideas?
(3,878 Views)
Hi Brenno,
I have seen this before and it has been fixed by repairing your install of VBAI.  I would give that a shot and see if it solves the problem.
Adam H
(3,863 Views)
I have a very big problem, and i can't find answer formy question. My problem is: I would like to execute an *.exe file, named : Ni vision Template Editor.exe. It is a part of vision development tool. When u start the application,  click first File -> new Template. This editor is used by another application for example: Vision Builder AI, Vision Developement Tool. And when u use this Editor from VisionB. A.I, it is needless to select a file to, open, the editor opens it automaticly. How should I do this, from LV code? I think I would use a kind of paramerer, or kind of property node, But i dont know how to do this. Could u help me? Thank you very much!
+++ In God we believe, in Trance we Trust +++
[Hungary]
(3,640 Views)
Instead of hijacking every thread why dont you start a new one?
(3,631 Views)
 🙂 yes, you are totally right, I am working on it: Thanx your fast reply! I think this would be the best way to!
[Hungary]
(3,626 Views)
