Machine Vision
Vision Assistant Generated .NET Code Produce Error
I have succesfully created AdaptiveThreshold application using Vision Assistant for image with gradient illumination. It is working perfectly.
Then i generated .NET code from the project. The problem is, .NET code always produce error when i ran the application. The error came up when i want to apply LowPass filter.
Here is the code generated by Vision Assistant (i also attached the complet VS project and the sample image on the folder):
using System;
using System.Collections.Generic;
using System.Collections.ObjectModel;
using System.Drawing;
using System.Text;
using NationalInstruments.Vision.WindowsForms;
using NationalInstruments.Vision;
using NationalInstruments.Vision.Analysis;
using Vision_Assistant.Utilities;
namespace Vision_Assistant
    static class Image_Processing
        //public static ReadTextReport vaOCRReport;
        public static PaletteType ProcessImage(VisionImage image)
            // Initialize the IVA_Data structure to pass results and coordinate systems.
            IVA_Data ivaData = new IVA_Data(9, 0);
            // Image Buffer: Push
            Functions.IVA_PushBuffer(ivaData, image, 0);
            // Extract Color Plane
            using (VisionImage plane = new VisionImage(ImageType.U8, 7))
                // Extract the luminance plane and copy it to the main image.
                Algorithms.ExtractColorPlanes(image, ColorMode.Hsl, null, null, plane);
                Algorithms.Copy(plane, image);
            // Filters: Low Pass - Filters an image using a non-linear filter.
            VisionImage lowpassImage = new VisionImage(ImageType.U8);
            Algorithms.LowPass(image, lowpassImage, new LowPassOptions(25, 25, 5));
            Functions.IVA_PushBuffer(ivaData, image, 1);
            // Operators: Subtract Image
            Algorithms.Subtract(image, Functions.IVA_GetBuffer(ivaData, 0), image);
            // Thresholds an image into 2 classes by using local thresholding.
            LocalThresholdOptions vaLocalThresholdOptions = new LocalThresholdOptions();
            vaLocalThresholdOptions.DeviationWeight = 0;
            vaLocalThresholdOptions.Method = LocalThresholdMethod.NiBlack;
            vaLocalThresholdOptions.ParticleType = ParticleType.Bright;
            vaLocalThresholdOptions.ReplaceValue = 1;
            vaLocalThresholdOptions.WindowHeight = 50;
            vaLocalThresholdOptions.WindowWidth = 50;
            Algorithms.LocalThreshold(image, image, vaLocalThresholdOptions);
            // Filters an image using a non-linear filter.
            // First, increase the border size, if necessary.
            if (image.BorderWidth < Math.Max(3, 3))
                image.BorderWidth = Math.Max(3, 3);
            // For each pixel, the algorithm takes the neighborhood specified by the given filter sizes
            // and replaces the pixel with the nth smallest value in the neighborhood.
            Algorithms.NthOrder(image, image, 3, 3, (int)Math.Floor(3 * 3 / 2.0));
            // Lookup Table: Equalize
            // Calculates the histogram of the image and redistributes pixel values
            // accross the desired range to maintain the same pixel value distribution.
            Range equalizeRange = new Range(0, 255);
            if (image.Type != ImageType.U8)
                equalizeRange.Maximum = 0;
            Algorithms.Equalize(image, image, null, equalizeRange, null);
            // Lookup Table: Reverse - Inverts the pixel intensities of the image.
            Algorithms.Inverse(image, image, null);
            return PaletteType.Binary;
Please help.
Best Regards
(4,855 Views)
Can you please attach the Vision Assistant script?
Thanks.
Christophe
(4,849 Views)
Here is the script.
Best Regards
(4,840 Views)
Here's stack error :
NationalInstruments.Vision.VisionException was unhandled
  Message=Exception of type 'NationalInstruments.Vision.VisionException' was thrown.
  Source=NationalInstruments.Vision.Common
  VisionErrorText=Invalid image border.
  StackTrace:
       at NationalInstruments.Vision.Internal.Utilities.ThrowError()
       at NationalInstruments.Vision.Internal.Utilities.ThrowError(Int32 success)
       at NationalInstruments.Vision.Analysis.Algorithms.LowPass(VisionImage source, VisionImage destination, LowPassOptions options, VisionImage mask)
       at NationalInstruments.Vision.Analysis.Algorithms.LowPass(VisionImage source, VisionImage destination, LowPassOptions options)
       at Vision_Assistant.Image_Processing.ProcessImage(VisionImage image) in C:\Users\kusumy\Documents\National Instruments\Vision Assitance\OCR Processing. NET 2008\ImageProcessing.cs:line 35
       at Vision_Assistant.Form1.RunButton_Click(Object sender, EventArgs e) in C:\Users\kusumy\Documents\National Instruments\Vision Assitance\OCR Processing. NET 2008\Form1.cs:line 36
       at System.Windows.Forms.Control.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnClick(EventArgs e)
       at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
       at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
       at System.Windows.Forms.Control.WndProc(Message& m)
       at System.Windows.Forms.ButtonBase.WndProc(Message& m)
       at System.Windows.Forms.Button.WndProc(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
       at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
       at System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
       at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
       at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
       at System.Windows.Forms.Application.Run(Form mainForm)
       at Vision_Assistant.Program.Main() in C:\Users\kusumy\Documents\National Instruments\Vision Assitance\OCR Processing. NET 2008\Program.cs:line 17
       at System.AppDomain._nExecuteAssembly(Assembly assembly, String[] args)
       at System.AppDomain.ExecuteAssembly(String assemblyFile, Evidence assemblySecurity, String[] args)
       at Microsoft.VisualStudio.HostingProcess.HostProc.RunUsersAssembly()
       at System.Threading.ThreadHelper.ThreadStart_Context(Object state)
       at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
       at System.Threading.ThreadHelper.ThreadStart()
  InnerException:
Please help
Best Regards
(4,803 Views)
The problem is solved after manually set image border width before applying low pass filter.
Best Regards
(4,802 Views)
