Machine Vision
Variable Image data to NI Framegrabber
I am developing a cameralink camera wherein
the user will be able to toggle via serial various
pixel lengths for a given line in a linescan camera.
Mainly, I will do pixel binning via the camera's
FPGA.
Using NI framegrabbers, will I be able to display
this using one or no .icd file?
Thankyou.
(3,106 Views)
Hello csk,
You should be able to make your own .icd file using the Camera File Generator utility. You can download it from this link : http://sine.ni.com/nips/cds/view/p/lang/en/nid/14207. You can even use this utility to test serial communication with your camera.
If you are using LabVIEW, you will be able to use the IMAQ Serial subVIs to send and receive serial information between the framegrabber and camera.
I hope this answers your question.
Vivek Nath
Machine Vision
(3,086 Views)
