Machine Vision
VI Server call from CVS system
I'm running into problems trying to do VI Server calls from my CVS system to a LabVIEW executable running on the remote machine.
I've got a simple LV app (log.exe) that receives data via VI Server calls. So, I update its front panel controls remotely.
The other vi (call.vi) opens a reference to the LV executable (log.exe) and calls the appropriate functions (Ctrl Val.Set [Flat]) to give information this exe.
First scenario:
log.exe running on my machine and call.vi being called from LV. Everything is working fine.
Second scenario:
log.exe running on my machine and call.vi being called from VBAI. Everything is working fine.
Third scenario:
call.vi is deployed to the CVS system.
log.exe is running on my machine.
call.vi returns error code 66 in VBAI on my CVS system.   [error message = "Open Application Reference in call.vi"]
And yes, I changed the machine name from localhost to the IP address of my machine.
I think I configured everything OK for the log.exe application. I've attached the ini file to this message.
Note: I'm using port 3364.
Any idea what can be wrong?
Are there any issues I should be aware of when trying to call the VI Server from a CVS?
I'm really having problems with this, and I should get it up and running quickly!
thx for all the help....
Message Edited by noxus on 09-12-2007 04:34 AM
(3,207 Views)
Hi Noxus,
It looks like your setting up the system correct. Could you post some example code then I can have a look at it.
Karsten
(3,158 Views)
Hello Karsten,
Thanks for your answer. I've resolved the matter by using a different approach. (not using VI Server anymore)
thanks again for the help!
(3,130 Views)
