Machine Vision
VBAI 3.5 Ethernet comm with Omron CJ1M
Does anyone have any sample code in CX-Programmer to communicate with a CJ1M over TCP?
I think I understand what I need to do in VBAI but unsure on PLC side.
(4,963 Views)
Hi BAM787,
I'm afraid I can't be of much help regarding PLC communication, but the Vision Builder for AI (VBAI) TCP I/O steps are well-documented in the help file, which you can find in Windows systems at Start » Programs » National Instruments » Vision Builder x.x » Documentation » Vision Builder AI Configuration Help. Within there, browse to the category Configuring Inspection Steps » Communicating » TCP I/O.
It's possible some customers here have some experience working with CX-Programmer, but have you also tried finding some forums specific to PLCs, or especially any specific to Omron controllers?
(4,942 Views)
Got it. Used built in TCP function blocks in CX-Programmer. Turned out to be pretty easy
(4,811 Views)
Hi, all
Is anyone have the command syntax about link Omron PLC with LAN?
I can use RS232 to read DM, but I don't the command for LAN.
Please mail to me if you have any idea. very thanks.
Jean
E mail: jean.chu1@gmail.com
(4,555 Views)
Hi Jean
With a LAN connection you should be able to communicate with TCP/IP. You should also consider contacting Omron for any protocols or function commands that you need the PLC to run.
Thank You
Eric Reid
Motion R&D
(4,534 Views)
