Machine Vision
VBAI 2014 Buttons in the Interface Panel
Hi
we are using VBAI 2014 for an inspection and we want to use some buttons in the interface panel to control and configure the inspection.
Is there any user manual which describes the usage of buttons at VBAI? Are there any information about the usage?
Can anyone give me some tipps? Or is the usage only possible with LabView?
thx
Oliver
(4,336 Views)
You can definitely use buttons on a Custom Inspection Interface. When you add buttons on a UI, they will appear as "previous measurements" that you can use in different places in VBAI.
Typically, you would check the value of a button in a transition, and create a specific state to handle the action you want to do when the button is pressed (use the Switch when Pressed mechanical action).
Does that make sense? I am attaching a simple example showing how to use it that way (rename the attachment to .vbai)
Hope this helps.
Christophe
(4,328 Views)
here is a helpful link:
Customizing the Inspection Interface in NI Vision Builder for Automated Inspection – Part I - National Instruments
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x59kCAA&l=en-US
(4,307 Views)
