05-25-2011 07:54 AM
Concern: VBAI 2010
Hi,When I use a calculator tool, I can't write caracters using the 'alt gr' key in a formula node. In the same way, I can't use the 'ctrl X' shortcut.
Can I change this?
thanks for your help.
05-31-2011 07:56 AM
Thank you for posting your question on National Instruments' Forums.
I tried to reproduce the error you mentionned, but without success. I can cut/copy and paste informations inside the forumal node and use special characters too.
Can you post a screen capture of your problem, so that I can see chat is happening ? did you modify anything in the configuration settigs ?
Have you tried to repair your installation of VBAI ?
Guillaume H.
National Instruments France
06-01-2011 04:13 AM
I just have changed the setting "hideBDPopupMenus = False" in the file Vision Builder.ini.
I don't know how I can show you this problem with a printscreen.
When I select some text and make "ctrl X", nothing happens.
And I can't write "{ }". I have to write special caracters in a text file, copy and paste it in the formulanode.
Thanks for your help
