The most common cause for the error "IMG_ERR_VLCK -- can't lock on video source" (error -1074397153), is that your camera is not properly connected to your board or your camera is not powered on. A defective power supply and/or cable is often the culprit, so that would be the first place I would check.
For more help in troubleshooting this error, please see the Knowledge Base, "What Are the Reasons for the Error Message "Can't Lock on Video Source"?" at http://digital.ni.com/public.nsf/websearch/F5CD44FEE5BF3841862565A3007AAE64?OpenDocument, as well as the Knowledge Base "My Color Composite Camera Causes the Error "Can't lock on Video Source" at http://digital.ni.com/public.nsf/websearch/9cfae22b35ea542786256533007dd384?OpenDocument&Highlight=2,12GGr5q4.
I ho
pe this helps!
D. Putnam
