Machine Vision
Using IMAQ for Aerial Aerial Robotics development. Need help.
I am trying to use IMAQ for my college research for my Autonomuous Aerial Vihecle(Flying robot-either model Helicopter or fixed wing airplane). Does anyone have any idea what is the best hardware to load with IMAQ that is light, small and support IMAQ realtime operation?
(3,082 Views)
"If you require analog imaging with RT operation and PXI that pretty much will limit you to using the PXI-1407, PXI-1409 or PXI-1411. They will all be the same size and approximate weight. If you are just looking for a monitor, you may also consider using IMAQ 1394 with a firewire camera, but this will not be compatible with an RT system."
(3,082 Views)
