02-07-2006 02:02 PM
02-07-2006 07:03 PM
Hi Chandran,
Have you tried using the "File Options" cluster input on "IMAQ ReadFile" ?
02-08-2006 08:58 AM
Hi Prashant,
Yes I tired that, but it seems that the IMAQ create vi that is called before IMAQ ReadFIle overrides the "File Options" cluster.
When I call the IMAW create vi, the file type is set to I16. I get pixel values from -32768 to 32767.
I tried setting the IMAQ REadFIle options to set the min to 0 and max to 65535, but this didn't change anything.
Thanks for your reply, I'm still searching for a solution.
-Chandran
02-09-2006 08:06 AM
02-09-2006 01:35 PM
Hey Chandran,
I would recommend that you check out the following discussion forum called 16-bit greyscale colormap. One of the posts on that thread has an example VI, but you might want to double check to make sure that it does what you want.
DJ L.
02-20-2006 07:31 AM
02-21-2006 02:55 PM
12-28-2007 02:12 PM
12-31-2007 11:26 AM
01-25-2008 06:44 AM
