Machine Vision
User Defined roi
Hi Experts!
I have a simple question.
Is there any way, to create User defined ROI?
For example, I would like to create a ROI, like: Crosshair.png
+++ In God we believe, in Trance we Trust +++
[Hungary]
(4,137 Views)
Accepted by topic author D60
Yes and no. You can combine this ROI from three basic ROIs: two lines and circle (or annulus). Movement will be a little bit tricky (because all three ROIs should be moved together by mouse movement) - you have to do programmatically. Example ("starting point") in attachment. Otherwise think twice - may be it will be more easy to use single point ROI with overlay instead of multiple ROIs.
Andrey.
(4,132 Views)
Thanks! You are great! Could you convert it to LV09? Thnaks!
[Hungary]
(4,130 Views)
Attached for 9.0
(4,128 Views)
Thanx!!!
[Hungary]
(4,127 Views)
