Machine Vision
Update tolerances in VBAI in real time via ActiveX?
Check out this document.
http://zone.ni.com/devzone/cda/epd/p/id/1139
And this one explains the syntax to use to access shared variables using the datasocket API.
http://digital.ni.com/public.nsf/allkb/8D2FE9AC6ACB8B3F862571B0007FAECA
-Christophe
Message 41 of 44
(1,049 Views)
Ok, I have looked at the examples and started to try in VB6.
In VBAI if I create a network shared system variable called "test", wich URL for the datasocket should I use?
I tried many combinations, but none worke (I get a connection error status).
Message 42 of 44
(1,047 Views)
I answer myself. The url value should be:   "psp:\\localhost\Vision Builder\test"
Use the  SelectURL("localhost")  method to display the avaliable shared variables.
Message 43 of 44
(1,044 Views)
The URL syntax to access shared variables from datasocket is psp://computer/library/shared_variable
Try psp://localhost/Vision Builder/test
Message 44 of 44
(1,043 Views)
