06-22-2006 01:52 PM
06-23-2006 08:09 AM
06-23-2006 01:15 PM
Hello Patrick
Thanks for taking your time to review my little issue.
I will take a look to the code you just sent me, I need to finish the software i'm writting, I have my boss
behinh me with this issue.
Thanks Again
Best Regards
Reynaldo Lima.
06-24-2006 10:47 AM
Hi Patrick. Good morning.
Hope you're doing fine, I'm doing fine. I took a look to the vi from you, It's what I'm looking for. I tried on my
sequence, but I'm havin a error con the unbundle, it say one wire is missing or not the correct type. I couldn't find
whats the problem. What I'm trying to do is to find templates on a faceplate, I need to detect if the faceplate was
assembled right. I want to know if the template i have are in the faceplate and in the correct place. I'm thinking
to compare ROI and template, I think the SCORE value will help me also, Need to be accurate.
This is the way I'm doing. but I'm getting trouble.
Reynaldo Lima V.
Best Regards
06-25-2006 02:59 PM
06-27-2006 09:25 AM
Hi Patrick. good morning.
Thanks for your help the VI you sent to me, it's working good. I put it into my main sequence and is OK, I was stuck with this issue, Thanks Again.
I'll keep in touch.
Reynaldo Lima V.
