Machine Vision
Unable to read QR code
Kindly ask for your assistance.
Trying unsuccessfully to decode a QR code through labview.
I'm able to read the code through online QR scanners (such as: https://www.online-qr-scanner.com/) or with some python codes but not with LabVIEW.
I'm attaching a small VI and an example image.
using LV2018 32bit. have vision module installed.
Anyone know what's the issue?
thank you in advance.
(2,511 Views)
Accepted by topic author Tamir87
LabVIEW is a little more strict about the barcode requirements.  You don't have enough empty border around the barcode.  I added a small border with the same background color and it reads fine.  Try attached image.
Bruce
Bruce Ammons
Ammons Engineering
(2,483 Views)
interesting, thanks for finding a solution for my case!
(2,463 Views)
