Machine Vision
Unable to create Labview VI using Vision Assistant, I get error messages e.g. Couldn't open NI DiaDem or couldn't open Connectivity,..
The Vision Assistant script runs fine by itself, I try to create LV VI when the LV program is not running
(3,124 Views)
Is it possible for you to post screenshots of the particular error you are getting?
Does LabVIEW run fine on its own? There is a particular file that might also be throwing an error. Did a file called "LabVIEW DIAdem Connectivity VIs 3.0.2.exe" get put into your folder C:\Program Files\National Instruments\LabVIEW 20XX? If it does get put there, what happens when you try to run it? It should simply extract and put files into your LabVIEW directory. Let me know what happens?
Ravi A.
National Instruments | Applications Engineer
(3,115 Views)
