Machine Vision
USB Camera in Built Executable
I have just installed the USB IMAQ drivers and have now integrated a USB camera into an application.
The problem is I cannot get this app to run as a standalone exe on another machine.
I have installed the vision71rte.exe and run it on the new machine and other IMAQ (non camera) functions are working correctly.
I have also copied over the file 'imaqdirectshowdll.dll' into the Win\sys32 folder as without this an error message appears saying all the USB IMAQ vi's are missing.
However, even after the above is completed the USB cam will not work with a standalone exe on a new machine. Am I missing a particular dll or what, any suggestions please.
Paul@ccsln.com
(3,290 Views)
Hello
Make sure you have dll  ImaqDirectShowDll.dll   and ImaqDirectShowExport.dll. Register last one (regsvr32....)
Also, the usb camera driver must be installed.
If you are mising some imaq dll, browse this site , There are some help about what imaq dll have to be installed.
Hope it helps.
 Alipio
"Qod natura non dat, Salmantica non praestat"
(3,284 Views)
