Machine Vision
Trouble using serial output strings from smart camera to plc
I was hoping that someone on here could steer me toward the best manual to use that would give me specifics on the serial commands.
I am capturing a datamatrix code then outputting that via the serial commands. When I output through the serial I get jibberish. I have not broken down the ascii to see waht the jibberish is yet.
I am using hyperterminal and realterm on my development computer in place of the plc. I should be seeing numbers not jibberish..
I attached a rtf file to this post with several screenshots. I really hope someone out there has some information.
I had to put the file in a .zip to attach it...
(3,018 Views)
Hey Tailfire,
I found another Discussion Forum that may be of some assistance.
Serial Communications
Let me know if this does help any. If not I will look further into this.
Ricky
(2,999 Views)
