Machine Vision
Transparent bottle detection........
what kind of lightings we can use for detect the defection in transparent bottle neck?(like UV, IR which will be the effective one for transparent bottles.....)any suggestions................
(4,520 Views)
XRay may be? Just suggestion................
(4,509 Views)
What kind of defects are you looking for?  That makes a big difference.  This might be a good application for dark lighting.  You could put a light on either sided of the bottle.  Good bottles won't show anything, but any defects will reflect light back to the camera and be clearly visible.  This can be a great way to find surface scratches on glass.  You could probably see bubbles and internal defects as well.
Bruce
Bruce Ammons
Ammons Engineering
(4,501 Views)
If these are glass bottles, UV illumination may be interesting, see http://www.uvcorder.com/pdf/ADI0608UV.pdf and http://www.pentax.fr/downloads/cctv/de/pentax_uvlenses.ppt.  The image on page 11 is interesting.
-Robert Eastlund
Robert Eastlund
Graftek Imaging, Inc.
Phone: (512) 416-1099 x101
Email: eastlund@graftek.com
(4,493 Views)
Thanks Bruce,
   i have to find the defection in bottle neck  ( the top of the bottle) so i think if the light is focussing from top means it will be good.... if we focus from top means.... we can get the perfect  circle of the mouth(if it is good bottle)..... for that what type of lighting we can go..... and i have to find both transparent and some colored botlles like brown and green.......
(4,468 Views)
Hello Kalanga,
I hope your issue is resloved. Please dont hesitate to get in touch with NI for further queries.
Karun
(4,455 Views)
Dear Kalanga,
For illuminating the top rim of a transparent bottle, I would suggest using a darkfield illuminator, see the attached darkfield.jpg image and http://www.nerlite.com/Dark-Field.html for information regarding darkfield illumination.  The sample image is of a clear bottle.
-Robert Eastlund
Robert Eastlund
(4,422 Views)
