Machine Vision
TimeStamp
I am using a Jai camera and would like to know the exact time at which frames have been acquired.
Using IMAQdxTimestampLow I get some numbers for the difference in times between frames, which I cannot correlate to the FPS.
Anyone ?
Thanks.
Message 1 of 24
(4,823 Views)
And the block diagram....
Message 2 of 24
(4,821 Views)
Hi ratus,
have you looked at this example?
http://decibel.ni.com/content/docs/DOC-4531
Joseph Tagg
Message 3 of 24
(4,794 Views)
Thanks for the reply.
Actually, the GetMetaData.vi I am using is similar to this example.
Best
Message 4 of 24
(4,791 Views)
It is similar, but you need to make sure you combine both parts of the timestamp.
Message 5 of 24
(4,787 Views)
Just have done it and it gives the same results.
Message 6 of 24
(4,783 Views)
Ok.
What is the loop cycle time? Does that correspond to the FPS?
Message 7 of 24
(4,775 Views)
As I acquire the next buffer, I think the loop cycle does not matter that much with this buffer acquisition (buffer length 1000) ?
So I guess I really acquire @ 200 fps which is also the specification of the card.
W.
Message 8 of 24
(4,771 Views)
I looked back at the example I sent more carefully and there is the following note:
Caveats and Additional Notes
You will notice that I have divided the U64 by 10^7 before converting to timestamp.  This is because timestamp takes an input of seconds (it represents the number of seconds that have passed since Midnight, Jan 1, 1904), and the U64 contains values in 100s of microseconds (or tenths of milliseconds).  This may vary a little bit for different cameras, so if you are not getting an accurate timestamp, check to see what the quotient is.  You may need to adjust the constant for your camera.
As you can see, the actual value returned by the timestamp should be determined by the camera. Check there to make sure that it is being interpreted correctly. It seems that your program gives a x-y of 1s if the U64 is really returning tenths of milliseconds.
Message 9 of 24
(4,752 Views)
Well, I would have to divide by 2.08000E+6 to get a time interval between frames of 5 ms....
Not sure it corresponds to something.
Message 10 of 24
(4,747 Views)
