Machine Vision
These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match.
Hi, I'm getting an error updating LabVIEW 8.2 to 2011:
These cannot be wired together because their data types (numeric, string, array, cluster, etc.) do not match. Show the Context Help window to see what data type is required.
The type of the source is cluster of 2 elements.
The type of the sink is typedef 'IMAQ Image.ctl'
IMAQImage (IMAQImage,<no tag class>).
This type mismatch may be caused by an older instance of the Image data type.
To fix it, simply replace the instance with the IMAQ Image.ctl type definition in the Image Controls menu palette.
The source is:
Call Library Function Node - image(dup)
The Sink is :
IMAQ_array to image - image
I've tried deleting the IMAQ_array to image VI & replacing it but it still won't connect...
Here's a pic of the VI,  I have a number of VI's to update and they all have this problem
attached is the VI also.
Cheers if you can shed any light on this 🙂
(4,050 Views)
Accepted by topic author converge
Found solution, it had to do with representation of images in old and version of Labview
I'm completely new to NI Vision so I had no idea what I was looking for
from this thread:
http://forums.ni.com/ni/board/message?board.id=200&message.id=5849#M5849
(4,038 Views)
