Machine Vision
There is no result after calibration,why?
I use "IMAQ Find Vertical/horizontal edge" to find the edges of a rectangle, and make the outputs of these VIs as the inputs of "IMAQ convert pixel to real world". Then I choose a point from each Vertical and horizontal edge, use "IMAQ points distant" to measure the length and width. But there is no result. I don't know what the problem is.
Message 1 of 1
(2,877 Views)
