Machine Vision
Texture Analysis
With regard to the vi's posted below (cooccurence.vi.zip and ParamTexture.vi.zip), these are for LabView v7.1. Unfortunately, the version I have is 7.0, and I can't open them. Could you kindly re-post them using an earlier version?
Thank you so much!
Message 11 of 16
(3,367 Views)
Hi Steverino,
Hopefully you have already seen my post on your other topic, regarding VB. Either way, I have saved these VIs back to version 7.0. You can reference them at:
Is there an IMAQ Vision function that calculates a co-occurrence matrix?
Hope this helps,
Robert
Message 12 of 16
(3,363 Views)
Message 13 of 16
(3,318 Views)
Hi Charley,
Thank you very much for the VI’s you provided. I want to use them to segment different plants by texture analysis. But I have color pictures. Is it possible to use these VI’s for color texture analysis? I have configured the attached algorithm, do you think is it correct?
Regards
Abbas
Message 14 of 16
(4,198 Views)
I never worked with color images, but I suppose that it should be possible to separate the different color planes and apply the co-occurence method to each. There are probably other solutions, and some bibliographic study should be worthwhile.
CC
Chilly Charly    (aka CC)
Message 15 of 16
(4,160 Views)
Eskay,
I am also investigating a texture based application.
If you are interested in collaborating, please contact me.
I would also like to hear more about "NI Classifier". I was not aware this existed.
Doug Wilson
dwilson@pvisys.com
Doug Wilson
Message 16 of 16
(3,247 Views)
