Machine Vision
SubVI missing
I am on the project using NI VISION. I am working on a detection of objects. I have one program but i cannot use again because they are explaining me that I have a subVI missing
This subVI is IMAXdx.ctl and i cannot find this anywhere in my computer
Do you have any ideas for fix it ?
Thanks in advance
(3,755 Views)
This is not the right forum for questions. Use the Discussion Forum: https://forums.ni.com/t5/Machine-Vision/bd-p/200
(3,751 Views)
If the IMAQdx.ctl is missing, this means you don't have IMAQdx support for the selected LV installed. Try installing Vision Acquisition with IMAQdx support for the LV you are using to fix this problem. If it's already installed, try doing a repair.
Hope this helps,
Brad
(3,750 Views)
