Machine Vision
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Sub-pixel measure
im trying to apply a sub-pixel function in my project, but its doesnt works.
i trying to measure  thickness of a circular part.
Anyone has a example (.vi) that use this function to measure some distances, that really works? ( Ex:10,52mm part -> Measure 10,52 or 10,53)
(4,457 Views)
Hi Jeff21, good  morning.
First we need to know what devices you have to make your measurement ?
Filipe Martarello
(4,437 Views)
Good Morning Filipe.
My devices:
CVS 1455
Digital Camera - SONY XCD-SX910/X710 (firewire)
Jeff
(4,435 Views)
Hi Jeff,
First you have to install LabVIEW, LabVIEW Real-Time, Vision Development Module and CVS Driver.
Then ou can see some examples at LabVIEW 'Find Examples'. You can see more about vision at: http://www.ni.com/vision/ .
National Instruments offers a lot of courses including IMAQ. If you want to know more about it, call NI.
Filipe Silva
(4,408 Views)
Filipe,
I found the error, was the image.
Now i have a perfect image to use the VISION BUILDER tools.
But i would like to know what the best tool for Thickness measure on a circular object like a ring? (Find edges?, 2 Find circular edges and then subtract the values?, ...)
Jeff
(4,382 Views)
is an old post but I see in the forum that this problem is resolved, I've also been working for some time with a high-resolution camera with digital zoom adequate lighting and I can get 1mm menorahs measures nevertheless a margin of error brings , one might solve this?
(3,807 Views)
