02-15-2006 06:34 AM
02-15-2006 07:06 PM - edited 02-15-2006 07:06 PM
Message Edited by KevinC on 02-15-2006 07:10 PM
03-06-2006 11:09 AM
Particle Analysis does work much faster but there are other problems associated with it. Especially when two hits are close together (see image 22 and 29).
I have made a program that compares the output from your method and the convolute method, and also added a version with only the gaussian convolution - you can have a look at them.
If I cannot separate the hits then I will have to make a routine that identifies asymmetric particles and removes them - or at least counts them.
Best Regards
Simon Viftrup
03-06-2006 11:15 AM
03-07-2006 04:36 AM
