Machine Vision
Smart Camera Geometry Matching problem
Hello everyone, recently I bought a Smart Camera and Vision Builder. The initial concern is that it recognizes a rotating pointer and return the angle. The problem when using Pattern Matching, the results are far from good, and when I use the Geometric Matching there are obtained good results.But only running the step containing Geometric Matching, the Vision always returns error if I try to run the entire inspection. Could this be some kind of bug? The camera has some type of limitation to run code generated in the Vision?
With Thanks & regards
For reference I'm using the Smart Camera NI1744 with Vision Builder
(3,472 Views)
What is the error that you are getting? Any error code?
(3,457 Views)
The error message is attached. The error seems to say that the libraries of Geometric Matching are not being loaded, which makes no sense since other methods like Patern Matching are running normally.
Marcus Vinicius
(3,455 Views)
