01-08-2014 08:58 AM - edited 01-08-2014 09:00 AM
Have here a Prosilica AVT GT1600C and a very slow frame rate...
Here are my .icd information.
I tried to cope with the balance between the ExposureTimeAbs and AcquisitionFrameRateAbs but dont help.
The .icd file is attached (renamed to .txt), installed version: Vision 2013f2
Does some of the vision cracks find some optimizing issues? 🙂
thx in advance
01-08-2014 09:07 AM
Your file shows ExposureTimeAbs = "500000"
500000 microseconds = 0.5 sec, so indeed you would get just 2 images per second at that setting
The exposure attribute will dominate the framerate.... i.e. the target framerate could only be achieved if the exposure attribute is small enough.
Scott
01-08-2014 09:32 AM
Right, thank you for your reply.
The problem is, that with a lower exposure time my picture gets darker...
I dont know how to brighten it.
01-08-2014 09:41 AM
Ah well, yes... the variables/options are:
Scott
01-09-2014 03:14 AM
The Object (a display) is self luminous. I have a cover over cam and display to prevent other radiation.
Are there any programming options to increase the brightness?
01-09-2014 03:22 AM
I think i got it:
with the
Camera Attributes --> Controls --> GainControl --> GainAuto --> set to continuous (was off)
i got brighten
01-09-2014 07:02 AM
Great! Indeed, by default Gain is "off". If autogain gets you an acceptable image quality, then that's what counts. Just know that image artifacts like graininess or flecking can arise if too much gain is used... which is why I suggested the lighting is the preferred way to get better saturation.
Scott
01-09-2014 07:04 AM
Hi foxx,
is there anything I can help you with?
Best regards
suse
