‎12-09-2005 08:01 PM
‎12-12-2005 09:36 PM
blitzcraig,
Tough questions today (I just responded to another question you posted).
Well... the correct answer depends on how fast your new computer will be. LabVIEW does not have a speed limit (in other words, if you get a faster computer, LabVIEW will run faster).
So, you have two bottlenecks here, your computer and the firewire port.
Firewire can handle a maximum of 400 MBits/s which equates to around 22 fps for a 1080x1390 12bit camera. It sounds like your camera is speced to definitely handle 15 fps, but it might get a little higher (I doubt it can reach the 22 fps, but maybe).
So, if your computer is fast enough, you can definitely get 15 fps.
My computer is a 3.19 GHz Optiplex GX280 with 1.49 GigBytes of RAM running WinXP SP2. I have a Sony DFW-VL500 color Firewire camera attached to my machine. Running the camera at 640x480 and 32bit color I can achieve an average frame rate of 34 fps. That is 334 MBits/s, which is 60 MBits/s faster than your camera would need to obtain 15 fps at 1080x1390 and 12bits.
And with some fuzzy (extremely fuzzy) math we can approximate how fast your computer needs to be to achieve 15 fps. You are currently getting 5-6fps with a 533Mhz Celeron and 312 MBytes of RAM, you should get close by tripling your computer power. Realize that the 3rd party dll you are using to interface with yoru camera might add additional drag to your computer.
Have a Merry Christmas,
Lorne Hengst
Application Engineer
‎12-13-2005 05:18 PM
‎12-14-2005 01:28 AM
