Machine Vision
Simultaneous image generation
Somebofy might have the answer to my persisting code bug problem. I am working on microscope imaging here where I get my pixels to be formed on XY-coordinate 2D plane (or call it image array) from analog currents into my DAQ board. I need to sort of make two (2) different image windows (and file) from two analog input channels respectively. I thought that if I make to parallel loops of IMAQ Vision routine this will do the job? What I see is that cuts the image half and forms a clear demarcation line in the middle of the scanned image? What can be the problem?
Berns B.
Bernardino Jerez Buenaobra
Senior Test and Systems Development Engineer
Test and Systems Development Group
Integrated Microelectronics Inc.- Philippines
Telephone:+632772-4941-43
Fax/Data: +632772-4944
URL: http://www.imiphil.com/our_location.html
email: Bernardino.Buenaobra@ph.global-imi.com
(3,029 Views)
This sounds difficult to figure out without seeing any of the code. Perhaps you could explain more about which routines you are using or include a code example that show what you are doing.
The way I would do it is create a 2D array for each image, then just use ArrayToImage to convert it to an IMAQ image.
Bruce
Bruce Ammons
Ammons Engineering
(3,029 Views)
