Machine Vision
Show image
I am trying to display an image I have stored in my Mario( c directory), but nothing is displaying, any suggestions?
The Doug!
(6,029 Views)
what executes first (image display or image dispose) here?
what about here?
My answer is: I do not know!
You need to think dataflow. Check:
https://www.ni.com/docs/en-US/bundle/labview/page/block-diagram-data-flow.html
So you need to force the display before you dispose of the image! In your case, for example with sequence structure (although its best to avoid them in a real application...). Normally you clean after yourself only when the program ends (let's say when your main loop stops executing)...
So (a dirty example):
K
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(6,023 Views)
And kudos you will receive!
(6,019 Views)
