Machine Vision
Sending Image with Overlays to LabView from VBAI by using shared variables
Did you try using the Vision Builder API in LabVIEW ? It enables you to start a VBAI instance, load and run an inspection and also include VIs to get/set variables and get images as well.
I do not know how fast you want to update your images but my experience is that using shared variables to send images is not a reliable solution except if you update them slowly (1 or 2Hz maybe ?).
Sami
Message 11 of 12
(423 Views)
My attempt with SV was still in LV2009 times, but back then even 1Hz was not reliable.
Message 12 of 12
(412 Views)
