Make sure you are compressing your images properly. Look at the following
Knowledge Base to verify the method.
Compressed images will transfer faster over the network because of their smaller size. But the network and computer speeds will determine the maximum number of images that you can transfer over the network.
Depending upon what programming language you are using, you can refer to the following
Document to check out different ways to send images across a network.
Good luck with your application and have a great day!
Koninika
Applications Engineering
http://www.ni.com/support
