Machine Vision
Selected list NI Vision Builder
I would like to do selected list in NI Vision Builder to choosing inspections in Vision System. Now, it works automatically, it chooses inspections by barcode and run program, but the program doesn't work correctly now. I want to choose inspections manually.
Program works in this way:
1. The main program scans barcode and other things by picture made by camera.
2. When the thing is changed, program turn on another program which is between the main program and the next program. It looking for barcode and turn on automatically the right program to inspect.
 It worked well by couple years and now I have problem, beacuse I have to repair it. Are any tutorials or maybe somebody know how to do this? I do not have much experience with this program. I found function called "Select Inspection", but it works by choosing inspection automatically now and I don't know how to change it for manually select from selected list when the barcode is changed. Someone told me that to use LabView. I have got also file wrote in LabView which shows only actually barcode and function in NI Vision uses it. I enclosed screenshot of this file. Maybe in this function I can do this.
Thanks for advice.
All the best,
Maciej
Message 1 of 1
(2,402 Views)
