Machine Vision
Saved Tiff Images Are Being Inverted
I'm currently having trouble with saving captured Tiff images.  I am using the imgSessionSaveBufferEx() method to save the images.
The image are all grayscale, which is expected, but the shades of gray are being inverted.  When I do a snap the image looks fine.  However when I do a grab and save, the image is suddenly inverted.  I've attached resulting images from the snap and grab for reference.
(4,052 Views)
Hi brianbat,
What camera are you using?  And I'm assuming you're using CVI, what version of that are you using?  Also what IMAQdx drivers are you using? Thanks!
Matt S.
Industrial Communications Product Support Engineer
(4,025 Views)
Camera Model: Mikrotron MC1310
IMAQ version: 4.7
Application Language: 64-bit C/C++ - VisualStudio 2010
(4,019 Views)
Hi brianbat,
I would make sure you are using the function correctly, there are some examples that are installed along with the drivers that should be for Basic Read Image (VB): C:\Program Files\National Instruments\Vision\Examples\dotNET\1. Getting Started\Read Image\vb
Thanks!
Matt S.
(4,006 Views)
I am using Windows 7, x64 so I assume that within the path you provided the "Program Files" for me would be "Program Files (x86)".  If so, there is a Vision folder located within my "C:\Program Files(x86)\National Instruments folder.  However the Vision folder does not contain a folder named Examples.  It does contain a folder named dotNet but within that folder is an Assemblies folder.
-brian
(3,997 Views)
