03-16-2008 04:26 PM
03-17-2008 07:18 PM
Hi Darren,
I believe you are running into this issue because you are trying to change several instances of the same subVI. LabVIEW only allocates one memory space for this subVI therefore when you try to change it you are essentially only making changes to one subVI, not three separate ones. To work around this, you can make the front panel controls of Select Video Source -- Board, Channel, Serial Number, etc... -- inputs to the subVI. Here are the details to do this: Creating Connector Terminals for SubVIs in LabVIEW
Then make sure the subVI is reentrant so that you are able to make several calls to the same subVI. Below is a link with further information on reentrant VIs:
Does this solve your issue?
03-17-2008 07:33 PM
03-18-2008 03:36 PM
