05-19-2009 01:33 PM
I have a imaging system that's been running reliably for several years. Using a simple GrabImage function, I save the image to disk and it's done. The scientists I'm gathering the images for now are asking for some transformation of the images, to get them in an upright view. So I added the CWIMAQVision1.Symmetry myImage, myImage, cwimaqSymmetryVertical
and the CWIMAQVision1.Rotate2 myImage, myImage, 90 to the image before saving. The symmetry works fine, but the rotation is never applied. I've tried it in a few different ways from attempting the rotation first, last, pausing between the two, only performing the rotation, copying into another CWIMAQVision, nothing seems to work. If neither image manipulation worked, I'd say it was me, but the fact that the symmetry works and the rotation doesn't lends me to believe otherwise. I hope it's me, though. It's an easier fix!
Here's the snippet of code
Dim HistogramReport As New CWIMAQHistogramReport
frm17CImagerRunScreenHiRes.CWIMAQVision1.Histogram2 myImage, HistogramReport
frm17CImagerRunScreenHiRes.CWIMAQVision1.MathLookup myImage, myImage, 0, , HistogramReport(1).PixelRange.Min, HistogramReport(1).PixelRange.Max
'Set myImage2 = myImage
frm17CImagerRunScreenHiRes.CWIMAQVision1.Symmetry myImage, myImage, cwimaqSymmetryVertical
frm17CImagerRunScreenHiRes.CWIMAQVision1.Rotate2 myImage, myImage, 90 'rotate the image 90 degrees clockwise
' frm17CImagerRunScreenHiRes.CWIMAQViewer1.Attach myImage2
JPEGOptions.Quality = 1000 'Default = 750, Max = 1000
TempFileName = CurrentFolder & CurrentPlate & "_" & CurrentWell & ".jpeg"
BkUpImgPath = CurrentPlate & "\" & CurrentPlate & "_" & CurrentWell & ".jpeg"
WritePrivateProfileString CurrentWell, "Image" & NumPic, CurrentPlate & "_" & CurrentWell & "_" & NumPic & ".jpeg", CurrentFile
WritePrivateProfileString CurrentWell, "Data" & NumPic, CurrentWell, CurrentFile
frm17CImagerRunScreenHiRes.CWIMAQVision1.WriteJPEGFile myImage, TempFileName, JPEGOptions
I hope someone spots what I'm missing.
dave
05-20-2009 12:43 PM
