Machine Vision
Red-Green Color Composite
Hello!
Is there any way to get the red-cyan color channels from two almost the same images? Almost the same means now, that I made photos from an object with two cameras from two different positions, and I would like to show the difference between them in red-cyan colors (It's like anaglyph 3D pictures). I found also that picture is called color composite. Any idea how can I depict that in LabVIEW? Thank you!
gbbalint
(4,417 Views)
Accepted by topic author gbvbalint
Hi BBalint!
Here's an example of Color Plane Extraction, available directly fro the IMAQ Color Utilities palette. If the image is 32bit RGB, individual channels are returned as 8bit Grayscale.
To create the anaglyph, you will need to:
  • Align the two images corectly
  • Use te Red plane of the left image with the blue and green planes of the right image.
Best of luck with your application.
Regards:
Andrew Valko
NI Hungary
Andrew Valko
National Instruments Hungary
(4,387 Views)
Thank You!
(4,382 Views)
