Machine Vision
Reading image buffer
I'm using NI-Imaq (without vision) and I need to read image buffer. I 'NI-IMAQ Images and IMAQ Vision Images in C' but I just can't get it right (addressing problems I guess). I can save images all right, but I also want to access buffer data (I need to parse raw data). Could somebody explain (with example) how can I do it? Thanks a lot in advance:)
I'm using functions like:
imgSessionExamineBuffer (Sid, BufNum, &currBufNum, &bufAddr);
imgSessionSaveBufferEx (Sid, (void *)bufAddr, name);
(4,721 Views)
You should be able to treat the image buffer just like a 2d array of pixels.
After you call imgSessionExamineBuffer (Sid, BufNum, &currBufNum, &bufAddr);
currBufNum[0][0] Should give you the upper left hand corner pixel value.
Hope This helps,
Amaury
ni Applications Engineer
(4,721 Views)
Thanks for your answer, but still help needed with pointers etc. If I try to read buffer values for example print currBufNum[0][0], CVI says 'Pointer expected'). So there's still something wrong with my code (see Attachement). Thanks again:)
(4,721 Views)
Sorry...the array you are working with is actually a 1d array so the upper left hand corner is currBuffNum[0] for any pixel you can use currBuffNum [x+width*y].
Hope this helps.
Amaury
NI Applications Engineer
(4,721 Views)
Thanks again, but still no success. When I try to, for example, print pixel value to standard i/o -> printf("%l", currBuffNum[0]). CVI responses-> Type error: Pointer expected. Am I missing something (I know this is not so difficult) ?
(4,721 Views)
Solved the problem:
unsigned int bufAddr =0, currBufNum, BufNum;
unsigned int *user_buffer;
imgSessionExamineBuffer(Sid, BufNum, &currBufNum, &bufAddr);
user_buffer = (unsigned int *)bufAddr;
// Accessing to buffer values
printf ("Address is %d, value is %d, value +2 is %d\n",
BufAddr, *user_buffer, *(user_buffer+2));
imgSessionReliaseBuffer(Sid);
(4,721 Views)
