Machine Vision
Read .mts video file
Hello
I need to perform image processing on a video acquire by a digital camera in a .mts file
does it exist a way to directly read in in labview without converting it in .avi?
thank you
(3,378 Views)
Hello Mazzo,
in the following link you can find the possible supported image files. As you can see *.mts file is not supported.
http://zone.ni.com/reference/en-XX/help/372916J-01/nivisionconcepts/image_files/
If you are interested in only displaying a *.mts file you can embed a Windows Media Player viewer using ActiveX into your front panel. If this is what you're interested in there are examples on our website such as this link:
Play Files in Windows Media Player using ActiveX in LabVIEW:
https://decibel.ni.com/content/docs/DOC-2207
I hope this helps!
Antonios
(3,358 Views)
Unfortunately I don't need a simple visualization but an actual image processing of the file (pattern matching)
at least now I now there's no way to do it without converting the file
thankyou
(3,351 Views)
