Machine Vision
Re-install Vision 6.1 problem
Hi all
I have  re-install Vision 6.1 problem.
In our 1 computer station had installed the IMAQ Vision 6.1 for a long time. Around 1.5 months later, we had installed the LabVIEW Vision Development Modules 8.2 evaluation to try the features.
 After expired date, we decided to use IMAQ Vision 6.1 in this computer station. However, it can not run the Vision 6.1 so i remove the Vision Development Modules 8.2 evaluation and re-install the Vision 6.1. However, it still can not work  and it will show the error box in the below while installing
What's problem of this here?? Why we cannot use the previous IMAQ Vision 6.1???
Thanks for your help!!
Best Regrads
Steve SO
(3,075 Views)
Steve,
This error generally indicates a disk space error, or that your installation/uninstall has been corrupted. Here is an article that describes a similar, related error, and a possible solution.
Why Do I Get Error 1605 During the Installation of My NI Software?
If running the .msi files don't seem to fix the problem, I would suggest you uninstall all versions of Vision as well as LabVIEW. Then, copy all the contents of your Vision CD onto the harddrive. Finally, install LabVIEW, and then install Vision from the harddrive copy.
(3,056 Views)
