Machine Vision
RT and vison
I want to do a vision application on a realtime-system with a destkop system.
I would prefer a RTX System, but I heared it isn't possible? Is this right?
Do I need an ETS-System?
Kind regards
(3,425 Views)
RTX does not exist any more.  It was discontinued one or two LabVIEW version ago.
ETS works pretty well.  It just has the disadvantage of needing a second computer.
Do you really need realtime?  A modern multicore PC can handle quite a bit of processing, and the Windows latency is pretty small.  I think with multicore it is even less likely to interrupt a critical process, since Windows will only tie up one of the CPUs.  Unless you are doing control with critical timing, I don't usually see a need for realtime.
Bruce
Bruce Ammons
Ammons Engineering
(3,420 Views)
thanks for the answer.
Ok, it isn't possible to have windows and RT on the same desktop, isn't it?
In the first step a I want to do a vision application, after that I want to build up a position control. Therefore I want do the vision application also on the RT system.
Kind regards
(3,413 Views)
