Machine Vision
ROIToMask invalid image type
I have a Basler 102f Camera and acquire signals with 16 bit depth (effective depth is 12 bit).
When I try to use the IMAQ ROIToMask.vi I get the following error message:
"Error -1074396080 occurred at IMAQ ROIToMask
Invalid image type.
Possible reason(s):
IMAQ Vision: (Hex 0xBFF60450) Invalid image type."
Does anybody have a solution for this problem?
Dominik
(5,807 Views)
Hi groegler
The reason you are getting this error is that the ROItoMask vi only takes an 8 bit image as its input. If you are drawing the ROI onto the image I would cast your current image to a new 8 bit image for displaying and drawing. You will not see any difference as your computer can only display 8 bit greyscale. Then use this to create your mask with the ROItoMask vi. Then apply this to your original 16 bit image.
Hope this helps
Mike
(5,804 Views)
It works perfect, thanks alot!
(5,788 Views)
