Machine Vision
RGB value range
    In this attached vi, i am using k-mean clustering to determine the dominant color of an input image by combining the values of R,G and B.
In this i could able to find the centroid of the R,G and B values,but how to determine the range(distance) of R,G and B values.
Thank you
(3,937 Views)
Use the extract color planes VI to create 8-Bit greyscale images of the RGB planes.  Then either use the histogram vi, or convert the images to arrays, and use the array min max vi to get your range values.
Machine Vision, Robotics, Embedded Systems, Surveillance
www.movimed.com - Custom Imaging Solutions
(3,859 Views)
