Machine Vision
RBG from camera and convert it to CIE tristimulus
HI
I am acquiring a RGB values from simple web camera. I need to convert
it into CIE color values. The RGB values I am getting are by using the histogram
function and then getting mean values ofeach color plane. They seem to work fine
and respond to change in color. Now I need to convert that into CIE Yxy tri-stimulus
values. I am able to convert them into CIE using labview function, but they are a bit
out of sync than what they should be.
Yeshwanth Kadire
Message 1 of 12
(4,975 Views)
You can use "IMAQ RGB To Color2.vi" from the "Vision Development Module" (color utilities palette),
in order to convert from RGB to CIE XYZ.
Please check the XYZ white reference parameter, by default it uses the XYZ values of a standard D65 illuminant (6500°K).
Best Regards.
JC Benoit
Vision Engineer
Alliance Vision
www.alliancevision.com
Message 2 of 12
(4,962 Views)
Hi
thank you for your response.Yes I am able to convert them to XYZ values.
How accurate are these values.Like are they good enough to calibrate color.
I did convert them into color 1931 CIE chart. What is the color accuracy for this.
Yesh
Message 3 of 12
(4,956 Views)
Hello again,
How can I extract the "a" plan (from CIELAB) from a RGB image?
Message 4 of 12
(4,814 Views)
Hello Carmo,
Please try the attached VI and look at the Help (ctrl-H) and notice that there is the a* color output.
In the future if you would like more responses to your post, please feel free to create a new forum thread. Since this one had been inactive for a few months, its original posters will most likely not be looking back and therefore will not be able to help you.
I hope this VI is helpful.
Ricky
Message 5 of 12
(4,784 Views)
Tnanks, but this is only converting a single spot. I need to convert a complete image. I already try to use two For's with all thr RGB values converted, but is not very efficient.
Regards
Message 6 of 12
(4,737 Views)
Hi Carmo,
Are you using the above example in a couple for loops?  By "not very efficient" do you mean it isn't working on the entire image or it is just slow?
Justin D.
Justin D.
Message 7 of 12
(4,712 Views)
Yes I'm using the example in a couple of FORs.
Is not efficient because it takes more time than a if I use ImaqExtractSingleColorPlan to extract R, G ou B.
Regards
Message 8 of 12
(4,643 Views)
Hi
I am attaching a VI which I designed and it worked for me. The algorithm is simple.
acquire-->extract planes--> Set Region of interest--> Get Histiogram-->Get Mean value-->Get R,G,B.
If you donot want a ROI just take out ROI and extract from the VI. I you want values from each and
every pixel then convert it to array and apply math on the whole array.
If you have any other problems just let me know.
Do give Kudos to a someone you think has helped you.
Message 9 of 12
(4,637 Views)
Hello
I wanted to try this but it asks for states-logitech.ctl. where can I get this control?
Message 10 of 12
(4,323 Views)
