Machine Vision
Prosilica GC1380 Error 0xBFFF800D in MAX ...
I am trying to get a Prosilica GC1380 connected to LabVIEW. The camera works fine with the supplied software from allied vision and does show up in MAX. However, if i click on the camera in MAX i get:
Error 0xBFFF800B
The session for your  device could not be configured
If I run the CameraValidator I get:
Opening 'cam0'...
Error Occurred at unknown file, line 1880, column 14. Unknown element 'Endiaoess'
Unhandled exception!
Does anyone know what that means?
I have 2 networkcars installed on the pc
1. Intel 82579LM
2. Realtek RTL8169/8110
Both give me the same error.
I am running windows 7 x64 with NI-IMAQdx 3.9.1. My FIrewall is off and I already tried deleting the iic and xml file. Nothing worked so far. I have another computer and a Laptop where everything is working just fine.
Anyone got some good ideas for me?
Cheers
Jan
(3,771 Views)
Accepted by topic author winstroth
Hi Jan,
This looks like your XML file downloaded from your camera is broken. Is it possible you have some sort of pre-production camera? Can you check if there is a firmware update available?
Eric
(3,765 Views)
That did the trick. Thx very much. Strange thing that I did get that error on one computer but all other had no problem what so ever.
Well its working now so I am happy 🙂
(3,760 Views)
