Machine Vision
Problems with IMAQ write file.vi
Hi, I am new in the community and I have some issues with a Labview program I got from a colleague. The program is written with in Labview 8.6 and controls a camera (Guppy 160 b/w) and a translation stage. The camera is supposed to take 2 grayscale pictures when the stage is in a certain position. The bmp images are safed using the IMAQ writeFile.vi. For my colleagues setup it worked but I receive the following error message:
 "Error -1074396080 occurred at IMAQ Write File.
Possible Reason(s):
IMAQ Vision: (Hex 0xBFF60450) Invalid Image Type."
and the files that are written are empty.
Furthermore there is no information in the extended Labview help concerning the IMAQ writeFile.vi. I only found IMAQ writeFile 2.vi, but using it I get the same error message as before. I don't know what to do. Can anybody help me? Thank you in advance!
Lizzy
PS: You find a snapshot of the program (with the IMAQ writeFile 2.vi) in the attachement.
Message 1 of 8
(4,882 Views)
Accepted by topic author Lizzy
Message 2 of 8
(4,880 Views)
I seriously cannot understand the code. Why are you using so many local variables. Though i am one who is not against it but the flow is definetly missing here. What is pos 1, pos 2,pos 3. If the above link is not the case i will suggest you attach the vi instead for us to get  a better idea.
Message 3 of 8
(4,879 Views)
It wasn't me who made the code.:-) But thank you for the link! I figured out the problem. Although me and my colleague were using the same camera minemakes 16bit images and his just 8bit (probably due to a different driver). That's why the VI couldn't safe bmp-files in my application.
Thanks again!
Lizzy
Message 4 of 8
(4,870 Views)
Lizzy in that case you can mark my post as the solution.................... Right?:smileyindifferent:
Message 5 of 8
(4,867 Views)
That was my intention! I am not experienced in this... Sorry! Can I change it to your post?
Message 6 of 8
(4,856 Views)
Message 7 of 8
(4,831 Views)
And thanks......:smileywink:
Message 8 of 8
(4,812 Views)
